Still need to shave the front suspension, fix heater hoses and oil cooler with Scotty Customs sometime :P
Then need to sort out suspension/alignment as Im sure I was hearing weird noises at Sandown. Steering wheel shakes a bit on the freeway. and for some reason the rear left sits a good 2-3cms closer to the body than the rear right :/
Oh yeh, those damn heater pipes. (or should I say that damned manifold that touches them)
Interesting, are you sure the rims are the same offset? It sounds weird to have the subframe that far out, unless you hit a gutter drifting recently with all those powerz?
mmmmm dessert.
had a proper creme brulee (cream, not custard) for the first time the other day. bit disappointed, bit too heavy and creamy for me.
http://en.wikipedia.org/wiki/Cr%C3%A8me_br%C3%BBl%C3%A9e
this micra is going to be the little car that can, if you go through with all that you're planning. decked out from top to bottom.
inb4 Thule roof racks with single speed ontop and stance.
looool
don't forget the rusty jerry can and spare rims
Yeah prob touch base with you in March about that stuff
Yeah rims are same offset. I tried the Drfiteks, and then last weekend had the Xd9's on the rear and same issue.
Have never crashed the car, even when the car was stolen there was not body work damage. Me no know
Probably just drop off the car at Traction Tyres for them to have a looksie
dude they melted the engine... i'm sure it copped a fair flogging
Dezz doesn't like anything.
If dezz was a word in the dictionary, it's meaning would be; "He who hates the world and all it possesses"
the only thing dez likes is cocks and balls.
deep.
inside of him.
really deep.
like deep black like basti deep.
  • Like 1
Not much to laugh at there plattsy. Only issue with that pos exhaust is I don't have mild steel flanges. Should do the job though... Take it to Midas for fitting, I don't want my name attached to anything that shiteful. :P
scotty, my cut n shut sumps leaking, has a shit weld in one spot. ive put some JB weld to get me through.
reckon you could weld it for me while its still in the car? just one spot.
<3
i cum 2 yu
n i cum on yu
Not much to laugh at there mate. Only issue with that pos exhaust is I don't have mild steel flanges. Should do the job though... Take it to Midas for fitting, I don't want my name attached to anything that shiteful. :P
awwww dont be like that mang.... i wont tell anyone you touched me it.
<3
i cum 2 yu
n i cum on yu
Fair drive
Spose you want to rack up them km's asap
See you in Daylesford
nohomo
singaporeans don't know how to indicate. stopping in the freeway because she missed a turn.
much safe, much awareness, wow.
Gday Alvin
Ill be booking to stay at the "Big Hotel" on 200 Middle Road, Bugis
Yay or nay?
The woman that hit me in the hotel carpark outside my old apartment, singaporean licence, hit me while parking her hire car after the drive from the airport to the hotel... so less than an hour in the country.
Had to track her down after finding the car in a completely different area of the carpark based on paint transfer (15cm area) and she said she had no idea that she even hit my car.
"I don't... I don't know... I don't think... I don't....."
"YES BITCH YOU HIT ME LOOK AT THE AQUA PAINT ON MY CAR AND THE WHITE ON YOURS!"
/rant #stillangry
Guest
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
