out at morwell today and had no idea the smoke was so bad from the coal fire going on. you can see the ash in the air, it's building up on the cars. I don't know how the EPA deems it ok to be outside for extended periods.
epa dont know about it.
too busy sending out letters to car drivers.
  • Like 1
sorry to hear. didnt think JZ would be your thing
jay-z.jpg?w=680
Celsior or cressida with 1UZ is where its at for toyotas. JZ's too pricey.
you know big engine toyotas Alvin, what you think?
as mentioned, they're smooth and all, but they lack everything else, power, torque, and are put in cars too heavy for them.
needs turbro in the boot. coolant/radiator set up in the 1uz snorer is stupid, things are overly complicated.
just go 1J.
They issued advice to residents to consider evacuating today apparently due to the air quality (or lack thereof) as they can't guarantee how much longer it'll be like that.
sooo... 892kms on the hilux and it decides to run out of fuel.
stoopid gauge design... ill take a pic later. The needle and lines are misleading. its a terrible dash in general. instead of lines representing 60km/h, 80, 100 etc, it has a solid line all the way round then gaps missing on the 60, 80, 100 marks. actually makes it difficult to gauge if youre under or over speed limit. and of course their lever design reads 500kms in first half of tank and 400 on the second half. f**king toyotas.
Aw, poor you.
Get a pulsar
How many kw can a R33 GT-R fuel pump support in my gts-t? Ceebs going 040...
I've seen them pump out enough fuel to support 450rwkw in a GTR. I've also seen them run out of puff at 330rwkw. Luck of the draw really but will be more than you need.
How much voltage they're receiving is a huge factor in the flow rate (and I'm sure km's also could be a factor)... Wire it up using a relay to get full voltage instead of 15yo thin wiring designed for a smaller pump and you'll be laughing.
  • Like 1
I spy a Simon
Oh hai... Was on my way to the SAUVIC AGM, which was only 10 minutes from here.... or 1 minute if I had turned left instead of right at this intersection.
Guest
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
