signed up for drags at calder after track day. fuggit. already there, car should hopefully be ok, get plenty of runs in. will take 2 sets of wheels and just fill up at the BP on calder fwy (if not going E85 this week...)
Mum moved skyline out of driveway when I was out partying last night... nek minnut 2x brand new XD9's guttered and 2x panels scratched... f**king fuming.
The first set of rims I bought for my 33 back in the day...I was moving them out to the driveway to fit....Mum offered to help, I said nah it's all good I've got it...she ignores and helps anyway...rolls one a few meters and drops it face down... Thanks Mum :thumbsup:
6 day work week, now know that feel bro.
But...1620 after tax for the week...
Toby, does this qualify me for VWLBC?
What's the job?
Just filled up the ute...$104 fuaarrrk
  • Like 1
oh if you genuinely do feel that you "need" the latest phone, please kill yourself now... you have no life... clearly
well the blackberry shit itself. z1 is free. so might as well.
well technically not free. mom had a voucher for $300.
Edited by xALmoN
What's the job?
One is 8:30-5:00 marketing job, the other is Saturday art classes...
You still getting "supplementation"?
It won't be every week that I get that, second job is too seasonal for that to work :(
But while I can it's certainly nice, and a nice change from being unemployed.
Hey Dad, can you please put the rest of the wheel nuts on that wheel? Sure... nek minit cross threaded and new stud needed.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
