Alright, so i've compiled all the bits I need for ~270rwkw, only thing i'm unsure of is coilpacks. Would it be worth getting a set of Splitfires as a precaution before towing the car to Trent's? If so, there's a 2nd hand/nearly set on eBay for $450, is that steep or about right? Currently running stockies with no problems.
pretty sure i got mine for around 450 new delivered from nengun maybe 3 years ago
Can't remember what I paid for mine... think it was a little less than that though...
If you've got some time, I'd be ordering new OEM ones from amayama... be prepared to wait a few weeks though
Anyone got xforce catback here? how do you rate them??
http://www.xforce.com.au/products.php?make=FPV&model=101
can pick up a twin 3" for just over 1k new.
have had an xforce cat back and know a few others that have had them.
fitted fine and worked fine, some were silly loud others average loud, seems to differ depending on the model car.
i had 320kw on the stock coils with 190,000km
no point replacing them if they arent stuffed.
Hmm maybe i'll go with this for now. I've spent like 2k in the last few weeks on car stuff; that's a whole chunk of summer work down the drain. If they break down it's only like $150 for an extra hour of tuning I guess. My car has genuine 104,000 so might be okay..
thank god that japanese grandmother only drove it to church on sundays
  • Like 1
thank rajab that japanese grandmother only drove it to church on sundays
I'm gonna wing it and hope for the best. The coils aren't cracked or damaged, and as titan said, no point replacing if they aren't stuffed... Only one way to find out - more boost!
hit up artz. think he has some splitfires for sale.,.....
dont forget to gap your plugs down if you havent already....
Trent tuning it? He usually asks for new coils, either Splitfire or OEM, just so you don't waste his time. ;)
You should get that alloy intake today, I shipped it yesterday morning.
Cool, he has PM.
Yea Trent.. Okay I will keep an eye out for some splitfires then. Cheers for the quick postage, looking forward to seeing it; one of the final pieces of the puzzle! :D
Yeah try and fix any issues before you go to Trents
Otherwise you might have to wait a few weeks before you can book again
When you put in the 'new' coil packs might as well change your spark plugs too.
Probably even leave the cover off for easy access if Trent wants to double check anything
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
