good vid. looked like gtr_jet there, and that NXR was at Sandown in december. he ran into issues but looks like its running again.
Thats a Milano pulsar. Pretty sure it was an X1 which is AWD but they cant be registered because motor was never put on the compliance list or whatever. PGA guy has one and tracked once with me at Winton... till this happened: (cant add image for some reason)
ran a 12.6 1/4 mile before that though
good ol' CAs. and also why you should use ARP studs.
Both Jason and I ran at Calder that night. Jason popped his gearbox at Sandown but has since put another one in resulting in him running a best of 12.8 I think it was.
The best I could manage was a 12.6 but I could only net 110mph so something was wrong.
Had to get towed home after the Great Ocean Road cruise Saturday as the car started to run like crap. Got home and one of the bolts was missing out of my front turbo outlet so I guess that answers most of my issues.
wait... so you got towed home from the GOR on saturday because your car wasn't running, you get home and notice missing bolts... then take it drag racing 4 days later without repairing it?
She bought you a shot once lol. I remember his long haired ass getting us into the St Kilda location a couple of times, so can't completely hate on him either.
When the blonde bitch running door at La Di Da charged me a cover is when I stopped going. May return to the heart one day...
Do it fgt
Drags was before GOR cruise
OH&S lecture. Dragging on... and on... and on... and on... and on... and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on... and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on... and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on.. and on... and on... and on... and on..
and yet can be summed up with 3 words:
Use common Sense.
if you don't have common sense the darwin award is there for a reason..and try not to bread prior to being awarded it.
Use common Sense.
Ditto.
strong unaware of melbourne Grand Prix. queen st is farged. pulsar was sooo close to overheating and of course, there is nowhere to pull over. lucky.
stopped at Andrews Hamburgers in south melbourne for lunch. VWLHC
Pulsar needs more air flow to keep cool? You running thermos? Or just need a better rad?
Rad is fine, was worried thermos eerent coming on but pulled over and they were running. Hsvent been in suvh heavy traffic with it for so long before. 110 water temp on hand controller, never been that high before. Will see how temps go on saturday.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
