Most learned VWL, what's the go with allowing car registration to expire and then re-registering? Specifically wondering if there's any costs / need for RWC? I vaguely recall something about 3 months you can "re-reg" as opposed to "new-reg"... but assuming there is no way around the RWC etc. And if there's any additional re-reg costs... :S
All hard drive brands have their failures. I've got a faulty Seagate in mine, just cbf taking it out.
Didn't we swap that one over or remove it or something? can't remember now :(
I had an early model SSD die on me with a bunch of corrupted write errors, kept hosing my windows install... Friend of mine who built his PC at the same time had the exact same problem so we RMA'd them both... Serial numbers were 3 apart.
SSD Failures vs HDD Failures though, SSD's are awesome for reliability because of no moving parts... The Limited Writes isn't really an issue for home use unless you're using the first SSD's ever released.
^ This SSD SHIT on HDDs for reliability. ESPECIALLY on a laptop because its often moving places, placed down on desk etc.
Dezz do yourself a favour and make sure you get an SSD, heaps better than a normal HDD.
In terms of computer shops checked out scorptec? good service with decent prices.
your 1 year of rego starts on the day the rego expires, should you wish to rereg.
if you wait 2 months to re-reg, you'll have 10months of valid rego left, and still pay that 700ish.
This sounds a bit ridiculous. Having to pay registration for the months where it's unregistered = lolwut. Dat VicRoads cash grab.
when rego expires then you cannot drive car anymore.
if you pay it within 3 months then car rego again and all good.
after 3 months removed from system and you have to get full RWC and re-register the car
This is how I assumed it'll be. So if it's within 3 months, you DON'T need to grab an RWC, and just need to re-register the car? No extra fees? HOWEVER, then with regards to what Alvin said, you will be paying registration for 12 months starting from the ''initial" date it expired... as opposed to paying registration for 12 months starting from the date of re-registration ?
For example, lettuce say that registration expires 01 January 2015.
Scenario 1:
> Cannot drive vehicle as reg is expired
> As long as you "re-register" vehicle by 01 April 2015, you do not need RWC
> However, registration for "12 months" will only last until 01 January 2016
Scenario 2:
> Brand "new" registration required if registering vehicle AFTER 01 April 2015; RWC needed
> For argument's sake, say you do this registration on 02 April 2015
> Registration for "12 months" means this will be valid until 02 April 2016
These are the two possible alternatives?
Scenario 1:
Scenario 2:
senario 1
I've done it with the mustang now and then as it been off raod for 4 years.
Haven't looked at the links yet, but sometimes the CPUs can be slightly different models, screen size might be the same say 15" but different resolutions (higher resolution = better / clearer) and some may only have on board graphics, others might have an additional card. (nvidia or ati)
edit: checked your links quickly, aren't they all the R750JV-T4207H?
Edited by UNR33L
Ishan come to me when you've (stupidly) paid rego on a car that doesn't exist for 5 years just to avoid getting a RWC again...
Nah we took out one and gave it to you cause I was feeling charitable with my three hard drives. Then one of the ones we left in there carked it lol
All have the same CPU spec listed (Intel® Core™ i7-4700HQ Processor (6M Cache, up to 3.40 GHz) / Leap motion)
All screens and resolutions the same except the JB one being 15.6" vs 17.3" for the others... and all have the same Nvidia 4gb graphics card
senario 1
Interesting.
Haha wut. It's not that RWC is a huge deal, as-is should pass no problems at all as it did some months ago. Just the registration timing atm is not ideal for me - as if it were delayed say a month~ish, I can have dat dere concession reg pricing. But if there's fees such as just getting a RWC etc, gotta weigh up whether that time + money is worth the saving (not to mention the fact I couldn't drive it for x amount of time).
Guest
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
