I don't know if the hubs are different but it would be pretty simple to machine the sensor hole. If you want a set my hubs finally arrived for my billet uprights so I have a spare set
Hi everyone any help? Revving upto 3k Checked tps 0.48 & Throttle working alright. adjusted throttle bolt also tried unplugging tps but still same Nothing changed still revving same IMG_1261.mov
Was correct without the edit.
All 4 wires from the head unit into the converter. That's both channels, so you do not lose any bass information that might be in one channel and not the other (which decent music should have, but I'm sure the shit that the kids these days are listening to probably doesn't). Connecting both channels with alleviate the floating input problem highlighted by Greg above. As to what you should do with the outputs from it - they should also both be connected to 2 input channels of an amp that can sum the two channels and yield a single low passed output to a single channel. There is often a switch on channel amps to achieve that goal. If you're just listening to modern electronic music, then you can probably ignore the fact that there's two channels and just listen to one of them. If there is missing information it will probably only improve it by not being able to hear it anyway.
