Here is the bottom half of the shelf
I love my SM Whisky but will only drink occasionally
Also Victorialand is a long way from the GC but should you be up my way and if you ask nicely I will let you have a dram of your choice.
On that note. Gnite all
son of rajab Ants, you are more of a brand whore than freaking wheel collectors! You have like 30 bottles from only like 4 distilleries! :O
also no Japanese whiskey? VicWL is dissapoint
I have no idea how you can manage to have that many at one time however, I go through 1-2 bottles a month and have never manage to have more than about 10 at once... currently I'm down to 4
yeah I'm with you guys, they have bottleshops for a reason....So you dont have to store all your grog at home....Same with big ass fridges, I dont understand whey some people keep massive stocks of food in chest freezers in garage when there is a supermarket in walking distance from most houses..you can only freeze food so much before it's no good and you end up with freezers full of off food
Hoarders hey...
nope.
My favorite distillery is Highland Park. Hence, why it appears that is all I collect.
But I have
Glenmorangie (the nectar d'or is amazing), behind that is all the JW collection not a fan of blends.
Yes,
I do have Japanese Whisky which is really sensational and up there with the best (pretty sure it's already one of the best malts in the world)
Been wanting to get more but I has race car
Årdbeg for the ones that Luke their peat strong ;)
More HP with 25 winning several awards early this year in Scandinavia
Various SM including an Oz one -:
I also love cognac
And got other bottles in other cupboards
Like I said I drink it occasionally, don't think you're liver is in great condition if you drink that much and will eventually catch up with you
How much is the most expensive bottle in the above collection?
the most expensive bottle there FTM is Henessy Paradis extra rare congac approx $500 (well that's how much I paid for it back then)
Guest
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
