straight back fro NY or a few days in LA?
the jetlag with NYC-> MEL is a real kicker!
Last week was Vegas > LA > MEL
slept like 12 hours on way back cos I was so wrecked so not too tired anymore. (Although slept through the f1 :()
got done by Mansfield HWP on sunday. business as usual for the senior constable. even had a stamp with his details so didnt have fill in information about the issuing officer. looked like the whole force was out on cars and bikes in surrounding metro areas though... what happens when the number of speeding fines being dished out drops and suddenly theyre not making back the OT theyre paying the force? will they just cut it or make more of an effort to raise money?
also, i tried googling but couldnt find it: the way they work out detected speed and alleged speed. is it % based or just a flat number? Because I saw they changed the rules so that speedos should never read less than the actual speed, but thought that 2km/h is hardly significant when on a 100km/h road.
Detected speed is what showed on the radar, i.e. the speed you were actually doing assuming accuracy of equipment. Alleged is detected speed minus 2km/h if a cop and 3km/h if a camera, giving benefit of doubt which covers equipment inaccuracy and the odd chance your speedo is reading low...this is the speed that you get charged based on.
Speedos from factory are usually generous because the opposite creates law suits.
Therefore if alleged speed is a couple km over the limit, fair to say your speedo was probably displaying ~7-8km/h over the limit, unless you have recalibrated your speedo or changed your tyre circumference to a bigger size, which will make you as fast as or faster than what the speedo is actually displaying.
From what I hear most cops don't bother with 5km/h detected over / flamin mongrel fines. You would have to be picked on for them to get you for a couple km/h over. Cameras are a different story of course...
There's been a push from the top that they start fining for a couple ks over
http://www.heraldsun.com.au/news/law-order/traffic-police-told-to-target-lowlevel-speeding-offenders/story-fni0fee2-1226807937959
I don't understand that bullshit excuse...if the margin for error is that tiny before you enter the "danger zone" (i.e. exactly 2km/h over the speed limit), to warrant low speed fines...then why not reduce speed limits another 5km/h? As they are clearly too high with such a small margin of error.
VicPol seems to think humans are robots, what with our impeccable ability to maintain exact speed whilst looking at the road and their superhuman ability to detect decibel readings with their ears and distort reality with their minds ala Matrix style.
Vicpol's behaving erratically lately.
Went past a hwp 10k over limit, they didn't do squat.
Other day on monash went past bike cop at 20k over, he didn't do squat as well.
Are officers defying Commissioner Hill's orders or it's 'too much paperwork' for them?
I'll see what comes in the letterbox later on...
Guest
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
