garage cafe closed?
on another note, after driving a 458 I want one. gallardo was cool too but not as daily friendly #newlyfgoal
lol would you work on it yourself or pay the $1000+ for a basic service.
nek minnit 458 rolling on 20" ling long tyres and green stuff brake pads, running Penrite oil and ryco filters
  • Like 2
If you had a lambo or ferarri wouldn't care about the service costs probably
Dem lambo brakes needed a good squeeze before stopping, peoples faces priceless when 24 y/o rocking up at traffic lights paddle shifting down making all kinds of noise.
and oh man, many vegas stories for garage cafe meet lol
Edited by UNR33L
I believe that's against the law and would like to cite Events vs Stories (1986). IIRC the obiter dictum in that particular case was "those such events occurring in Vegas should thereafter remain there indefinitely."
Got any tips for Vegas? I'm heading there in November.
We sort of hanged around downtown because all the casinos are closer together, the strip you gotta walk so dam far to the next place.
Get a weekly (or how ever long you're there for) bus ticket so you can jump on and jump off up and down the strip, think they're 24/7
Do the exotic car driving thing (Like $400) but like an hour of driving few different exotics around the canyons.
Went to one of the clubs and saw red foo playing, was pretty insane (they always got celeb DJs n stuff playing at the clubs) - other than that mostly hanged around bars n stuff chatting to people and leads onto a good night.
But yes what happened in Vegas stays!
Edited by UNR33L
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
