anyone got one of those soniq tv's? probably getting one for the garage at home
not the best components i know.. but as long as it doesn't blow up i'm happy
$259 for a 40" (1080p LED) at jb is decent (last years model)
Kogan. 40 inch LED $299.
Had one, sister has it now, still works fine. Colour etc is pretty crap though, always looked mega washed out. I looked at a 55" when I bought my current tv but still looked pretty washed out. Much happier with my 50" Samsung for only slightly more coin.
Hopefully should be OK man.
Bought a few things with some mates awhile ago, when the package arrived my shoes were actually missing (no apparent reason, but could see in the picking slip it looked like whoever was collecting all the items just forgot or something -___-''), which was pretty annoying. But gave them a call / email and it was sorted out relatively quickly iirc. Still disappointing, but wasn't the end of the world; was sorted relatively hassle free.
They weren't missed they must have went out of stock between me placing the order and them processing it... Every other item on the list says sent bar one pair which says cancelled, and the order status says partially cancelled.
I know I'll get a refund but common sense would say email the buyer and ask if they want to choose another pair... Or at the very least, email them and let them know they'll be refunded etc
Tariquet... You can do better than that :P
grab yourself a 1979 Comte De Lamaestre (have to buy it online as the sole importer doesn't have a retail liquor license and can only sell to restaurants)
Don't disagree with you there.
I will take a look
Guest
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
