ehh rwd more fun!
I seem to recall some bloke telling me to drop my shaft in GTR and drive a 'mans' car :P
Birds saw you turn left onto FTG road this morning was at lights waiting to turn right. /csb
Will have to keep an eye out for you, I thought you left 10-15 mins earlier than I do.
Drivers be all like, it's wet on the roads I better drive 40km/h slower because I'm such a shit driver that I'm likely to lock up my brakes in the wet.
Love straight out exhaust on almost any car just to see how natural and beasty an engine can sound. Used to do it to most cars I'd put up on the hoist.
But gawd, the day I took the mufflers off my R1 and started it up. Shit shook my car port.
short pipes/side pipes = hnnnng
normal exhaust length without muffler/cat or hotdog = pretty terrible. DECA is all about SR's and RB's with no mufflers and they all get kicked off track days when they go to a circuit. half because loud, other half cause sounds bad.
yea 160kw, 4wd. picked up an 02 for a steal.
can pick up classics for sub 5k, cheap fun.
The wrx club only allow turbo subies to join up. The 3.0RB has 180kw, but is ineligible... go figure
i know is bullshit.....
we can be in a club together mate. you with your 3 litre and me with my auto.
Guest
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
