should have brought to me. did all 16 on micra in about an hour.
gentle love taps with hammer, some washers and an old wheel nut.
much easier than taking hub off to press
my studs are tack welded on. so not sure how to remove properly without damage. and also failed removing the current wheel nuts... pneumatic ratchet couldnt get them off.
Plus, needed replacement rotors machined down a few mm. so few birds with one stone.
thanks for the thought though.
tomorrow night (thursday night) meet at the new bunnings springvale (849 Princes Hwy, Springvale VIC 3171) at 9:15pm leave 10:15pm heading to docklands, got photographers coming along. :)
this means i need to wash the car before then somehow!
well if you ask any, im sure all will say yes. how many will send the work away to be done elsewhere.... not sure.
I think most machinists would do it, rather than just any old workshop.
Just bought 12x BKR8 spark plugs off the shelf at ferntree gully bursons. $4.50 each. notbad.jpg considering not many shops will even bother ordering them in for you. Just got to re-gap them all :|
So Bursons for bulk spark plugs and oil filters... Clayton Autobarn for huge Penrite oil selection.
How to make free money in 7 easy steps:
1. Be me and get $50 free bet from Sportsbet in email.
2. Deposit $50 to obtain $50 free bet.
3. Place free bet on 3 soccer matches in a multi bet paying 5.80:1 for a potential $240 profit
4. Win 2/3 matches
5. Hedge last match by putting your real $50 on the other team to win or draw, for 2.8:1 so you're at least guaranteed $92 profit even if the multi loses.
6. Your selected team wins and you come out with $190 profit from a free bet.
7. Have the self control to withdraw all $240 until they mail you again with another free bet or move from agency to agency,
  • Like 1
well local brakes place dont want to work on it because they have done it before and damaged hub. so will take it back to centreline. so will be there for cruise tomorrow :) but will need to hit Thomastown again sometime :(
  • Like 1
yo Alvin, trying to find copies of that movie you recommended: the Paella Magic one. Can only find rebellion, im on the hunt for the others. (save myself countless hours watching yet another melodramatic fantasy anime (i dont mind the first few hours, its beyond that when I want to shoot myself in the face))
Guest
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
