Yeah but don't understand the idea behind it, is it incase bike slides off don't want the originals wrecked?
This plus general scratches from shit flicking up from other bikes and your own, plus eliminating roadworthy items you don't need that are just deadweight. Sure I've left out a few reasons.
skiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiids.
and by skids I mean searching for front wheel traction.
should stop procrastination and take the dash apart to fit rev limiter and shift light...
dezz how come you changing all your fairings around to the white ones??
because trackspec i'm assuming
Fiberglass is cheaper and easier to repair...Has no lights etc, easier to get on/off quicker once fitted.. etc
On that note, any design/creative kunce that wanna photoshop some color schemes onto that photo, knock yourself out..
I'm leaning towards predominantly black with maybe some red/white highlights/sections, but feel free to change my mind with your designs.
The winning design will receive $5.
needed a new battery. of course place sold their last one 'just last week'. because of holidays etc looks like it will be late this week to get it, if that.
so impatient for these little things, urgh :(
I suppose. I don't think it's excessively crazy. But he did sink some money into it.
Called Autobarn, they wanted $399 for the battery haha jebus. Who actually buys at such a ridic price.
Guest
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
