"It's really hard to believe this could happen in a quiet little suburban street."
Quoted for stupid
Cause that's not the setting for 90% of serial killings
Why do people think they are safe in areas of obvious vulnerability / easy targeting?
sad.
but also +1 for poorly written article. If the reporter doesnt know what happened, just come out and say it or attempt to give us an idea. Don't say someone has been charged but then "it is believed he was known to the girls" huh? and then at the end of the article say the great grandmother and mother were home at the time? wtf.
and murder + arresting all done on Sunday, in court on Tuesday...? I thought these things took months to arrange. plus statements required from all people involved.
if SAU-Vic is so anti-red, then suggest something legit.
silver wheels on silver car dont work so well Plattsy.
something like the mag-blue as per image above? gun metal? chrome?
lol
I vote for mag blue. It'd look great on silver car.
  • Like 1
Red looks like clown wheels, inb4 GT3RS... NO, it still looks awful.
all im hearing is negativity. bring something to table pls
will also accept derwent pencil colour terms.
magenta would be cool.
I ran into a tow bar yesterday. Can that kind of damage (minor number-plate damage, tow-ball shaped dint in the front bar) be fixed, or do I need a new front bar? Also any idea as to which is cheaper? I've seen a stock front bar go for around $350 plus shipping.
this is just to read him his charges.
then potentially arrange bail.
this was def not a trial.
  • Like 1
Guest
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
