Ah k. Disc issues will definitely do that, exacerbated by any form issues too. Should speak to Dan in the gym section...he has similar issues with discs I think and has found ways around them. If you ever want me to take a look at your form I can always do that :)
Need to get back into it, just not motivated at the moment, spending 12 hours a day away from the house
you break one already? thought turbo wasnt on yet :P
I only know about 32a and 70V boxes. sorry broski.
all good man, your my pulsar guy, so any questions i have, i come to you!
apparently they where fitted to exa's n14's and 15's. with the ga16 engine.... might have to take a few wreckers trips.
How'd you do that, Tony?
My back wasn't 100% on back day (think i somehow tweaked it doing squats)
Come Romanian dead lifts I thought to myself don't be a pussy and do it phaggot. And the lower back back gave way on the way down
Struggled to walk and move for the next day or so. This was prob 2 months ago?
Started doing deadllfts again this week, concentrating hard on form and doing stretches prior. Normally i used to just go straight into a working set
hmmmmm maybe...
when googling, just include pulsar.org.au and any related threads should pop up. Or hit up the Pulsar Group of Australia, mate of mine is wrecking an N14 pulsar Q this week. (ill ask him)
Sometimes those injuries are good in the long term because they force us to reconsider and reset form; start from scratch again. More often than not you end up coming back stronger (unless you did some proper long term debilitating damage). Strongest bench I ever put up was after a shoulder injury that put me out for 6 months and had to start from empty bar again!
Also +1 for mobility stretches. Best way to pick up if something is wrong with joints / something not quite right and that you shouldn't put weight on them. The only time I adopt the don't be a pussy mentality is when tired. Learnt from shoulder injury that if something doesn't feel right I should play it safe until it does.
Yup was probably better for me in the long run :thumbsup:
gym thread that way ------>
Back on wasteland topic then
Do+you+even+feel+.+It+s+also+a+wallpaper
  • Like 3
sorry Platts, mates N14 was SR20.
try fb.
lol @ bodybuilding forum members having feelings.
course they have feels.
they where broken by alpha gettin thur gurl/guy thats why they lift.
it eases the pain.
zyzz_feel.jpg?itok=v0_4x2Frweights_before_dates_forever_alone_meme_
Guest
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
