I run ID's and if it's below 10 degrees my cars a bitch to start.
If the car has been on the trailer over night in winter and I try to start it at the track I have to wait for the temp to get up to about 10 before it will start.
It was tuned on a 35 degree day which probably didn't help.
Yeah on warm days, even anything above 15 degrees it starts first crank. Cold weather like today you can't even hear it fire a cylinder for the first couple of cranks.
  • Like 1
ive read a few articles mentioning the same amount.... maybe it could work.
id be taking it back to tuner and retuning in the cold tho....
Not a bad idea getting a winter touch up tune for it that I can switch to in the cold. Shouldn't cost too much.
yeah I didnt have any great issues either....Maybe its those crappy old Nismo injectors Birds ;)
I'd say it has more to do with the climate the car was tuned in and where you're starting it. My car gets left out on the street these days and inside the carport it does start much quicker. Pretty sure the bottom of my hill goes below sea level too, lol. Injector type or size should be pretty irrelevant; the timing and flow of them in the tune will matter more.
Besides, Nismo injectors are love...dat resale value through the roof. Just like my "outdated" PFC!
Need a tiny electric blanket around your fuel line birds.
Heh I was actually imagining doing something like this, but wrapping the whole engine. Also considered giving the fuel lines one of these
P.S. Medieval Lego ftmfw
Have a huge castle somewhere, so many trap doors and glow in the dark ghosts (actually just a regular Lego man in a ghost sleeve, but aren't they all!
  • Like 1
No, I prefer to get irrationally angry at people who get nostalgia about things that are 'silly new things that little kids are into'
Like Pokémon.
How dare this forum autocorrect and add that little thing above the E.
stupid nostalgic forum
well if your car is rwc...why worry?
sif be scared of tmu...just smile and nod politely as you do what they ask, then leave and do what the hell you want anyway
hmm only problem would be too low otherwise car is okay
always rely on much worse cars than yours to steal the spotlight. have seen bagged R32's scrape on modest carpark entrances infront of cops and they just watch to make sure no one does skids.
lol yeah this is true :P or i could just walk, market is pretty close. the melb car meets had a couple of people rev bashing and doing a skid on exit at the docklands one. :/
so you get told its too low...lift it...pass...then lower it again....
  • Like 1
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
