anyone seen an OP6 rear GTT turbo on a 20 with a steel wheel (not highflowed as such) and 20 odd pounds rammed down it's throat?
wanna see how far I can go on a 20 without increasing lag
Stock R33 gtst turbo will get close to 200kw
I've got a hks2530 with 20psi. Gets around 230kw
seeing as a 33 turbo cant get 200 legitimately on a 2.5 I cant see it making it on a 2.0
hence why I was wondering about the OP6 rear w steel wheel and lots of booooost
uwotm8? Boss wouldn't print me out the higher run, just wanted me to suffer so I couldn't brag of 200 wattz out of a stocker.
  • Like 1
Need someone to go out and look at it.. mudgee is 4 hours from Sydney
5k, treat yourself with another 33.
Just force your kid to crawl into back* and according to insurers it's still worth more than you'll pay for it.
*applicable to coupes.
don't want a cop magnet... we have discussed this
and 4 dr is MUCH easier
Lately, I've seen cops ignoring me at rbt's, driving thru cop hot spots, slightly speeding. Dunno if it's just me or cops aren't targeting at all (at least in north and east).
*shurgs*
Parts are accessible and cheap as f**k...1jzs are cheap as f**k...I have a fresh painted shell here in deep red if you want to build one...beautiful color...come have a look , get those creative juices flowing...onky f**k around is putting a manual in it..and its 92 model so won't get club reg for a few years....you can get 89 ,90 models tho
There was an jz engineered cressy in Brighton a few weeks back...under 4k..was.mint as ...
Guest
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
