Now needs supercharger / turbo so it actually goes fast.
Oh so an 86 owner is allowed to say this...
but when a NON 86 owner says this it's like we just called your mother a whore
  • Like 1
what do you expect us to be like?!? batman? smash you in the face for looking at me?!
lolololololol.
im just a happy chap nowadays, takes alot to wind me up and when someone does i usually feel pity for them instead of anger. :woot:
im too old for that shit.
The problem is you're focusing on the things in life that don't really matter. When I was a kid I had hopes and dreams. We all did. But over time, the daily grind gets in the way and you miss the things that really matter, even though they are right in front of you, staring you in the face. I think the next time you should ask yourself "Am I on the right track here?". Good luck.
are you quoting bioshock at me?!
So now it's "I know a guy who makes good manifolds". But when I said go see Scotty it was all like..thats gunna cost me a fortune man im not doing that I'll just buy bits from ebay and do it...
Can i say I told you so yet. ..no no I will wait and see if it works first....even tho I know it will. :P
It's a bit like the whole black person African American word thing really...there's a lot of history with our underpowered vehicles that you can't relate to and so you shouldn't say things like that.
Didn't end up pricing a kit; the Toyota dealership that was offering them had to pull out of it I think? Not that there aren't aftermarket options but we'll probably look more seriously into it down the track. In the mean time waiting for a turbo that never kicks in kind of sucks. I feel like a performance car should be able to break traction when you are foot flat to the floor, that it should have that limit that stops you going pedal to the metal - hard to go back from this.
Guest
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
