It's really not that bad the vulnerable are not that much worse off at all young people should work or be studying, they should pay to study why should the people fund their study? The dole should not be a free ride, Pensioners are still going to be far more better off than probably anywhere else in the world id love for them to have more if it was possible but frankly the rate it is going there would be nothing for anyone
lmao you're out of your mind. Just watch, this country will turn into Venezuela in regards to the Education system, i.e only the rich can afford to go to uni. Healthcare will turn into the US of grandspanking A, everyone too scared to go to the doctor in case they end up in debt for life.
Every single young person that I know is currently either studying or working, if they're not doing that then they're currently overseas spending that money they just earned. This whole budget needs to be thrown out on the basis that he lied about everything pre-election. It's nice and all to look down on others and think they don't deserve a particular incentive when you're not apart of that geographic. Please don't be so quick to believe what they want you to believe. I work with a pretty rough around the edges guy, and every time something about a european country, or a story on asylum seekers pops up on the radio during the day, all I hear is "f**king wogs, f**king boat people immigrant f**ks" ra ra ra for ages after the story has finished. Yeah I know, you're not like that at all, but shit if this budget isn't targeted at all the wrong people and therefore will begin separating the classes even more, then I guess I'm out of touch.
Lul wot? Escalated quickly much?
Yeah all young people too busy stretching worthless degrees and traveling the world instead of taking shit seriously. Then cry when they can't afford their next 6 month European holiday or buy a house.
Im bumping into first year uni graduates who are older than me and I've already been working 5 years with a 4yr degree.
I think young people have it way too easy.
Maybe once they realise university isn't a free ride, they may take it seriously.
/end rant #gettingold
  • Like 1
jerb, you has?
Guest
    • My theory would revolve around the ~4000rpm point being peak torque territory on an RB, where you're supposed to be looking at max efficiency of the head, etc, and....just not having it because the skinny ports are doing something to f**k it up. I'll admit, it's a loose theory.
    • It could be in the tune but in both cases it couldn't be completely solved or eliminated by some of the best tuners in victoria so I'm DOUBTFUL that it's in the tune or ECU but stranger things have happened of course. I've pondered that theory too but is there any theories that thinner and smaller ports overall would cause a turbo to spike? I would've thought it would just restrict it in general if it was small enough to make a difference. I wouldn't expect it to make a different at what is essentially sub 300kw at 4000rpm anyway. I think the next step is going to have to be the 6psi spring to rule out the idea that the gate is cracking open far too wide initially. At least that is the cheapest (free) thing to check initially.
    • I'm thinking it is skinny NA Neo port sizing and cams. Somehow.
    • -5’s did it. 8474 did it. Not hot side related. ECU related? 🤨🤪
    • Above you mentioned you only need to sand primer if there's an issue with it but with fillers it says the surface needs to be sanded to X grit beforehand. Does that sorta contradict that point as the primer hasn't been sanded yet? At the same time if I sand the primer, there's a good chance I'll expose the bare metal and I'm just chasing my tail at that point. Or I'll just use a sand sponge instead of sandpaper, it seems to be far finer in terms of abrasiveness as opposed to sandpaper. From what I understand, filler is like primer and needs scratches from the sandpaper to help it adhere to the panel. I realised the way I'm doing things is actually a bit counter productive as there's a chance after I put filler I will need to put epoxy primer again as opposed to putting the filler first and potentially no primer if I don't go to bare metal. Will keep this in my mind for the rest of my repairs.
