Vic Wasteland Thread
R31Nismoid
simone. mick says you has universal clutch tool!?!?!?
can i has use of for 10 mins?!
You may. I'll be home in Vermont South after 6pm, but I'm going out at 7:20 if you need it tonight. I can leave it in the letterbox if you want.
oh hai
new car is berry nice
hamish it has 2.3Lkit, 270deg cams, 1k injectors, clutch, flywheel, vipec and usual supporting mods with an evo 9 turbo on it
its tuned for 19psi and i havent driven it on 19psi yet, only 8psi and it flies / pulls awesome in every gear - made 240kw last dyno run
Anyone installed one of the HKS SSQ Blow off valves? Looking at purchasing this:
http://www.ebay.com.au/itm/NEW-Atmospheric-Plumb-back-Skyline-R32-R33-R34-RB-BOLT-ON-Blow-Off-Valve-BOV-/151073396294?pt=AU_Car_Parts_Accessories&hash=item232cad1646&_uhb=1
Wondering if it's better than the others on the market?
ah was just surprised the setting is even that low, as stock they run much higher?
then again you have a stroker... fun times.
mods collecting dust in my room and garage, need to strap them on to unleash the 2L milk carton fury
Ssq is fnf spec
yeah ive got no idea how it runs less boost than stock
my understand, at least from skyrine was you could never run less boost than the actuator spring
no idea how this is working
but its got an eboost 2 switchable between 8psi, 13psi and then 19psi
but stock i think is 19psi
Probably actuator is adjustable/weaker spring?
EJ20s will run less boost than actuator pressure if they're in Limp mode, I don't understand how it happens even without running the factory boost solenoid but it won't let it past 4 psi. I guess it must yank shitloads of timing to keep it down?
hence my initial " :O "
i've got a 3p sitting right next to me, will probably run 21-24psi all day everyday once tuned.
get an e85 tune, paul? would be nuts.
no idea
ill have to do some reading on the evo 9 turbo and the controller setup
my understanding was from the skyline setup
where you must run the minimum spring level, you can run higher, but not lower
get one of these.
http://gfb.com.au/products/blow-off-and-diverter-valves/deceptor-pro/deceptor-pro-ii--inside-car-adjustable-adjustable-bias-venting-diverter-valve2013-08-04-02-40-32855251378-by-gfb
you can adjust from plumb back daily to fully FnF style or in between all with a switch in the cabin!!!!!
Guest
    • Wait, the flappy paddles or sequential is the small penis indicator?  Either way, I can't afford it.
    • You and me both. If I ever get it running again, I'll have to look into cruise control.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
