Yeah I think I've got a stock 25 actuator hanging around... kept it in case I had to go back to stock, but I've since sold my stock turbo so not much use for it anymore.
It'll be the 5psi spring (it is increased to 7psi (+2) by the stock boost controller once above 5000ish rpm) but you can use for $20 bleed valve from ebay to do the same thing.
Edit: Btw Plattsy I pulled out my clutch alignment tool last night and put it in the power meter box at my joint in Vermont. So if you're in the area, give me a bell and you can go grab it whenever.
ha.
you know it prob will go 12 maybe even more. but i wnna start off safe, aint nobody got time for blowing an engine on a dyno.
im actually trying to source a decent second hand ebc. a friend has one for free but i need to do some work for him to get it.
i have no time.
i know i dont need it.
you dont need a 1j sat there rusting, but you have one. your point is invalid. i didnt need a turbo either.
any way. wheres good to eat around vermont, might as well get the preggo wife some food while im out!
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
