last engine didn't blow because of fuel... was just everything else sort of worked together to self-implode.
Once you understand the way ethanol and petrol ignite, you will see why e85 is so much better for engine longevity. Petrol explodes quickly at the top of the piston's stroke, when the crank is at tdc. That explosion has nowhere to push the piston till the crank comes around a few more degrees. This is why the rods/bearings need to be strong, they take the entire force of the explosion.
With e85 the explosion is slower and colder, meaning less force is exerted at the top of the stroke, more when the crank is at 90 degrees, which is the point of maximum torque, and least rod/crank/bearing stress. This is partly why you gain torque with a lower energy density fuel, and entirely why my stock engine handles 40psi up the straight at Sandown. ;)
man what the f**k is this shit, im just getting him to do a quick little run in tune so i can run it in properly.
shittttt scotty, sandy vagina and shit.
sandier than aaron the niggas,
which reminds me how is that nigga, i heard he was kidnapped by these whites and sold into slavery. f**king platsys cousins.
Hmmm interdasting.
Will consider it since things are back on the drawing board at the moment.
Considering having a chat to racepace about my oil setup, i have a feeling that is playing a role in my issues. Namely flow pressure and circulation with the cooler.
yeah because springs broke, causing rockers to scratch, causing cam lobes to be damaged.
all the while bottom-end bearing fails, rod comes loose, whacks the block and scratches piston an cylinder walls.
would E85 prevented that and engine would still be running 100%? I think not.
would the tuning required for E85 continually melt my external ignition coil? possibly.
would the extra power/torque cause enough power/torque to destroy my headset? possibly.
would the 50L fuel tank need constant jerry cans on standby? probably.
Oh man :(
That was first time around I believe... Not what happened last Saturday...
Ah mis-read it!
I don't trust plant juice.
Nah, can't afford to redo entire fuel system ATM.
Trying to save for a house/ fix up mums house.
Time to invest in something
I got this fabulous scheme you can invest in
Trust me im Asian
Shuttup terrorist
lol @ redoing a fuel system to handle E85. Bigger injectors are all you need, and a fuel pump, but most people do that anyway with their 98 petrol modifications.
Have switched back to 98 a couple of times and the engine is just so much happier on E85. Not even for the power; it's the smoother more consistent idle and feeling like a brand new engine compared to petrol, which you seem to be able to feel the mileage with. Starting in super cold winter is the only time it's not happy on E, but once she cranks you're all good.
Get on it! There's a reason you've never heard someone convert to E85 and say this sucks don't do it man. Even Hatish loved it. And lol my phone auto corrects to Hatish now.
There are a few reasons not to go E85...
The need for Jerrycans is one of the major ones since not a lot of regional centres have any E85 at all, so driving to Winton or DECA will use nearly a tank, then the track day, then the drive home...
I do 300+ peak hour km's each week in my car, I could easily switch to E85 (My pump can handle it, and my injectors are 550's... might need an upsize if I want to keep some decent overhead, I pass a few petrol stations with it each day), but its still the hassle of country trips which suck.
I'll do it in the future, but for now, I'm sticking to BP98
Lol @ autocorrect.
You just can't tell some people Birds... They need to go their own way, same as everyone else, as has been done for years. What they don't tell you at school is cars started life running on ethanol, and only converted to petrol due to it being virtually free to pump from the ground. Things have since changed obviously.
So... Your tank isn't large enough? That's a great reason... :P
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
