What is the best option for side feed injectors that are e85 friendly? Reluctant to convert to top feed at this stage
My car just turned 18 so can legally drink alcohol now
I thought you were selling your car Ric?
There are a few reasons not to go E85...
The need for Jerrycans is one of the major ones since not a lot of regional centres have any E85 at all, so driving to Winton or DECA will use nearly a tank, then the track day, then the drive home...
I do 300+ peak hour km's each week in my car, I could easily switch to E85 (My pump can handle it, and my injectors are 550's... might need an upsize if I want to keep some decent overhead, I pass a few petrol stations with it each day), but its still the hassle of country trips which suck.
I'll do it in the future, but for now, I'm sticking to BP98
Haha yeah
I haven't got Flex fuel tune at the moment, so any long road trips I need to look at e85 stations.
Wifey prob thinks Im a weirdo carrying a jerry can everytime we go somewhere far
Haha yeah
I'm expecting to love it too much to sell it when I get it back all shiny and new. Driving a rental corolla atm and not having powah is driving me mental haha
Who cares what wifey thinks, she's stuck with you now
There are only two e85 compatible injectors on the market I could recommend, ID1300 and Xspurt 1400. Both are 14mm top feed. Other sizes seem to handle it, like the other Bosch sourced Xspurts, but they weren't designed for long term ethanol use.
I can supply up to 550cc in sidefeed injectors, anything larger is generally a drilled highflow. (with the exception of Nismo 750's I think) You can generally buy a top feed conversion kit and the 14mm injectors cheaper than a set of sidefeeds too.
Top feed is an easy conversion, there are plenty of kits available to swap to top feeds on the RB25, and the RB25 Neo engine comes with them stock so it doesn't look out of place. A few have used the Neo rail on the older engine to keep the stock look.
Shit excuse, Simon. E85 conversion need not be permanent.
I've done the country trip on ethanol before, you just need to fill back up with 98 when the tank gets below 10 litres and switch to your heartily rich 98 tune that will run it fine.
As for DECA, if I wanted to do it I'd just switch back to 98 and drive up there on that, then do the event on that. If I wanted to do it on ethanol, it would take a little planning but I'd drive up on 98 with a couple gerrys of ethanol and swap it in when the 98 was low enough. Then same as above when coming home and stopped at a servo with 98.
Adding to Scotty's post, I've never had an issue with my Nismo 555s.
I remember reading a post that Trent made when he was first getting serious about Flex tuning and he was saying that it was taking 2-3 full tanks before the sensor was actually reading anything close to the pure/drained tank E85 figures.
This is true, but a good tuner won't be knife edging it to a certain percentage and you'll have no issues switching from <10 litres of 98 and vice versa. There's plenty of tolerance in a good tune, enough that I've been able to give my car stick after switching without issue. So my E85 tune isn't radical up top, but I still have an extra 40rwkw in the midrange to muck around with.
Some of the guys in the ethanol thread tried to tell me that my E85 tuned engine was going to detonate from accidentally copping a tank of 70% lol
Guest
    • On 12th June, the mechanic could not figure out what the issue was, but the car seems to be flooding with fuel. He was suspecting the tune, thus referred me to a tuner. Although the tuner is not familiar with Nistune, last Monday (30th June), he came over to try and re-map it. Despite the tuner trying to completely stop fuel, it kept sounding like it was pushing fuel. Tuner ended up suspecting either the ECU or Injectors. I do not believe the ECU or Nistune is the issue, as the Nistune software reads and communicates properly. Today, I removed the (new) injectors to see if they are clogged or leaking. Surprisingly enough, after those 3 days of driving, injectors 2 and 3 look very blocked. You can see the difference in the picture. I blew a bit on 3, that is why it doesn't look as clogged as 2. I am still unsure if this is what is causing the no start issue, but I am now feeling that I may have bought the injectors and Nistune without the need to do so, as the problem seems to be coming from somewhere else.
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
