of course somewhere in the world, someone will have a headlight for sale, but given the confines of the medium in which she asked, until somebody states otherwise in this thread, mohsen is in fact, correct.
What confines? It's the interwebs lol. I don't think Leesh was intending to source one exclusively from a person who posts in this thread.
Don't allow Moh to have this victory
then why not post in wanted to buy section, instead of here, the specificity of the post dictates that mohsen is correct no matter how much we dont want him to be.
logic dictates he is a winner.
Moh will be victorious whether you like it or not. He is the Osama bin Laden of 9/11 as he is the terrorist to this argument
picturing moh sat in his fridge and oven filled cave in the mountains laughing maniacly.
then why not post in wanted to buy section, instead of here, the specificity of the post dictates that mohsen is correct now matter how much we dont want him to be.
http://www.skylinesaustralia.com/forums/topic/443523-33-passenger-side-headlight/
Logic? Gooby pls
Location of the question is irrelevant, butthurt though that may make you.
An emphatic 'no' is simply not correct. You conceded that. Framing the question in strange contexts of your own choosing is a red herring.
In summary, f**k Mohsen.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
