So, Saturday night I had an altercation.
Drinks flowing, everybody joking around. Ripped a joke with some body, he took it seriously and waited till I turned around before he had the balls to take a swing.
Piece of shit goat lovers.
Now at the ear and eye hospital, awaiting possible surgery. Vision in the left eye permanently impaired.
Also. Wtb. 1000cc injectors
Fark mate, doesn't sound good.
Greg is upgrading to 1400's and has 1000's he wants to get rid of. I can ask him if you like. Or I can get new Xspurt 1000's modified to suit an RB26...
f**king coward.
Go to cops & get him charged, then convicted.
Use conviction to aid in filing civil suit.
Sue him for every penny possible.
Once he has paid whatever he can, take him back to court to obtain judgement against him for the debt + costs and force bankrupt him.
Ruin his life as much as possible - legally
Fkn got dman
What did you say? Let us know how your eye turns out. Did your friend step in and sort him out? If not get him done for assault
Apparently I instigated it, I don't really remember the lead up to it but someone was saying I was calling him a fag lol, apparently. I remember him playing along and saying let's go on the grass, all fun and games and he got serious so I left it and walked off.
One mutual friend said that's sexual harassment...
you could have f**ked his mother in front of him. he still cold cocked you.
hope you well mate. ive been glassed before, its not cool.
im guessing he hit you with something to f**k up your eye?!
This is perfect opportunity to call cousins and get old mate cut.
So if he waited for you to turn around, why is ur eye injured?
even more of a dog act.
you confront the flamin mongrel one and one and beat the f**k out of him. telling him your going to do it before hand.
Guest
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
