Interesting deposits Dave...did you drain the fuel rail and injectors before you cling wrapped them?
Probably is sugar...
well obviously not :P 4 months it took to get like that...maybe condensation was building up inside cling wrap...not sure... need to do some testing...I have 10lt od e85 here maybe i should put it in random things and let it sit....see what corrodes ;)
Ah well of course it's gonna leave some shit in there then...would dissolve the moment you run more ethanol through it. Though on first start it may make the ethanol a bit crap. That is one reason we say to leave petrol in there to "pickle" the system if you're leaving your car dormant for extended periods of time. But I don't imagine that sugar shit causing any harm anyway.
Quick recommendation on new headlight globes since mine blew last night.
Thinking either OSRAM or Philips Xtreme-vision, but open to suggestions...
I've used Philips and Narva?, much of a muchness i think
Im not too shabby a solderer but circuit boards are so much easier than free hand. Struggletown even doing RS232 with jaycar kits. Smell of cooking skin is stronger than solder
Come solder my lights
I put the xtreme vision in the missus Mazda3.
tested it with a lux meter I downloaded on the phone and saw about a 40% higher lux reading in the same exnvironment.
very noticeable difference when driving in the country as well.
BUT I've run the same in the ute and they do blow more often,
as the saying goes, those the burn twice as bright burn half as long.
  • Like 1
Narva plus 120 or Intense if you like white/blue light
But I'm not biased or anything...
Can supply soldering iron and lead-free solder.
cant say id do a very clean/tidy/good job, but will work.
If your bored on the weekend come around!
Otherwise was going to buy a solder on the weekend and fix my front indicator light, as the wiring as torn off
Guest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
