ok all sorted
the rear facing fog light switch actually turns the front ones on too - go figure
its probably like that from factory but seems odd that a rear facing fog light button turns on the front ones
they're a wierd looking light, it seems like light comes out of them but from behind the globe itself, not a direct beam, very cool :D
ok how the frig do you see the engine number on this thing
i cannot for the life of me see mine at all
there's shit everywhere in the way
will vicroads have a wah if i cant actually see it ?
like it know where it should be but its too hard to see .... ?
They might not even give 2 shits to look for it. If they do then let them look around and find it. Not your problem.
On a somewhat related note, rwc bloke couldn't find my engine number on the Subi and put another number which I'm guessing is just manufacturing related down. Glad I picked up on it else coulda been potential drama at Vicroads.
happy bday alvin?
haha also i've seen that jonoe, smh.
but it did make me want sushi. so am going to grab sushi as post-exams meal with some chums. which will probably sub-par, but will make up for it in quantity... #unilyfisthepoorlyf
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
