y'all whinging about someonewho has dialogue and a name nobody remembers being killed off.
back in OZ, average of 1 character death per episode. that shit ran for 6 seasons. OZ was doing it before it was cool.
needs moar boobz, and swords.
And dragons and zombies
THANKS A LOT TONY! I HAVENT WATCHED IT YET!!!!!
NICE SPOILER TAG! ARSEHOOOOLE!
In unrelated news...
http://www.urbandictionary.com/define.php?term=Polished+Turd
Example: Gold Plated RB30
10361596_10203105833819458_5555090403995
Jumping on car list from few pages back.
89 R31 wagon, full of rust, parted out
88 R31 wagon, swapped for coupe roller
86 HR31 GTS coupe(base turbo not natro) bought as roller, sat, collected some bits ended up on eBay
91 Hyundai excel, rolled
88 Honda prelude, bought with front end damage, repaired, filled with coolant, leaking, figured water pump gave to workshop to fix/rwc, turned out block was cracked in accident, left it there.
96 R33 taxi, drove it, loved it, shat auto, took off road, threw money at, sat, got over it, parted out
93 R33 coupe, bought t boned, parts car, parted out
86 Toyota Corolla, borrowed off mum, shat engine, replaced with engine from other, shat gearbox long time later, mum cbfd so went to scrap
85 Toyota Corolla bought for $100, pulled engine, sold for $100
81 Nissan Bluebird, bought from original owner, low ks, dailied, shat head, replaced, cam gear dowel somehow came out of new head on test drive, turned both heads into 1 good one. Went to ballarat, bottom end died on way, towed, probably still at depot
95 Nissan Maxima, bought off sister to replace bluebird, now going to my dad
93 Subaru Liberty RS Turbo, new daily fun car
Finished all 7 seasons of big bang theory last night. Love that show
that's like over 50 hours ... how, in one night...
despite all that's said above, i am a bbtheory fan. provides lulz to me err week. also penny.
and yes, get on game of thrones.
I said I finished it last night not watched every episode
Guest
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
