ah cos its absolute pressure
ie at idle or sea level pressure is 14psi or 100kpa already
so pressure is 262kpa, minus 100kpa
gives run time boost at 4800rpm
162kpa, gives 23PSI, geez
i wonder if thats right, thats from the vipec map sensor
the eboost one doesnt show that high
hmmmm
yeah not sure on the "statistics" page
some of them make sense, some are really way off
ie # of times started and run time in minutes seems reasonable
but then you look at peak ECU temp, 13000deg celcius???
max intake temp 12,000 deg
max volage 184
probably worth clearing them
but then kinda dont wanna clear the # of times started and minutes
Why, they are unrealistic too...
Started 36,000 times...that's 10 times a day everyday for 10 years and average 1 minute per run. Unless granny drove it to regularly and compulsively check for mail at the end of her driveway, or it had some serious starting issues, I call bullshit.
yeah the max temps and max #s are really really wrong
but the run time in mins and started sound somewhat believeable
i plan on keeping the car so ill probably erase the stats back to zero
cos it would be kinda handy to have some of the top scores over time
but currently theyre all whacko
cos it tracks # of times you hit limiter, #s injectors max, total knock etc
but currently they're all mega high
I felt an accomplishment driving into Bayswater @ Import monster and leaving without a defect today
fark that's lucky as! i heard pettit was hosting a defect shop near barry st bayswater today :s
nasty
whats the defect for
height below 100mm, pod filter unsecured pod filter and exhaust doesn't comply with noise standards. also have to provide a rwc. fun times :/
Luck of the draw mate, eastern burbs just increases the odds
true that :( booze bus turned into defect station.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
