I sat in Nick's evo seats shortly after I got my GTR seats, was mad jelly. Then again maybe I'm just not wide enough lol
GTR seats definitely more comfortable than EVO for the larger posterior
+1 for Recaro SR2 / SR3's
Comfortable, look good but not over the top racer look, can do 300km+ trips with rough suspension and not need a new spine or butt replacement at the end.
I've had lots of positive comments from passengers in my car (who know nothing about and don't care about cars) saying stuff like "Ooooo I love these seats, they're really grippy"
Unless the GTR seat breaks its back and you have to drive DECA like a Mexican in Inglewood
I think Basti was in the car and shat himself when I went round that cone and ended up in the back seat lol
Farkin lol
I just remember laughing at the sight of the back missing from the chair. Deca sitting on a milk crate would add a new dimension of skill to it.
and this is why looking for after market race seats.. it is for a track car after all.
I'ld prefer a fixed back, but I like to store stuff in the back between track days.
One of each then?
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
