Depends on lines; with baggage, the earliest, I call 8:45.
If you're trying to skimp on airport parking then park at Maccas and wait for phone call...or chance your 20 minutes in the wait and collect zone on the way to terminal 4.
Or do what other tight asses do and pull over on the Tulla pretending to be broken down lol
The maccas outside the airport can be a pain for parking since all the chauffeurs park there... Try getting off the exit before the airport, there's a much bigger maccas just at the exit. Think that exit is called mck something.
thats a kinda busy time at airport, on a plus note it means more ppl working. lucky it just b4 a 380 but if her flight delayed it will push out quickly.
I normally go with 30 min.
that said I have been in a taxi in under 10 min from landing once!
make sure you track the plane to know the actual landing time and then work with 15-20 min from that.
RS5 y u no drag me. You didn't buy the sports model, you bought the racing model...why do this if you're gonna take off like a Hyundai Excel. Did the smell of burning sugarcane scare you?
Answer me!
Answer me!
ill drag you big fella.
just gimme a while to sort some tyres.,....
speaking of. anyone know anywhere around dandy area that can open the centre bore on a set of wheels?!
Answer me!
RS4 was no racing model when I drove it, my guess is the RS5 isn't much better.
even worse this morning
but when you command a 350kw battle ship nothing is a racing model :woot:
Perhaps. I just expected more.
I think it needed twin turbo and ethanol, but there just wasn't room, and it was a hatch so no boot. :P
only rs model ive ever driven was an old rs6 wagon from (i think) early 2000's. was a mint car on das autobarn.
Take the "Freight" exit, which is currently used for the Long Term Parking, on your left there will be a waiting area designed specifically for people like you who just want to hang out and wait for planes to land so you're not doing laps constantly or clogging up maccas.
http://melbourneairport.com.au/news-events/listing/overview/ring-ride-waiting-zone-.html
Mickelham Rd?
This. I sit in the car park till i know the person has collected baggage, then sit in pick-up zone waiting for them. If you get kicked out, do a lap round the block and start again.
BRING IT OOOOOOOOON
Meh, I just don't drive to the airport since it costs me $80 in fuel for the trip.
Came back from Sydney on Monday... Long Term Car park from Saturday 7am until Monday 11am cost me $70 (3 days).
I seem to remember leaving the car there for a full week once, and I think it was about $90... Blergh.
Guest
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
