Thought those kits were like $6k...
I would go supercharger, but only if roots type. The centrifugal ones are basically turbos anyway, just a little less laggy.
I think the turbo will be more fun and a roots blower better for drivability when you want to fang it.
Yeah basically!
Umm... both? hahaha To be honest, I'm not even 100% sure what I want, all I know is I have boost withdrawl symptons ever since selling my 33 and in search of my next boost hit :(
Reading this, go the turbo...it's obviously the spool and sudden rush of power from a turbo that you miss. Blowers are a more linear in their delivery! Though that centrifugal type will have a bit of a come on.
just pm him is all im saying.
mine worked out to be shockingly cheap.
I'm just assuming it's going to be way too much of a headf**k, especially with the crossover pipe from cylinder bank 1 to cylinder bank 2. Not doubting Scotty's skills, just trying to save him from a major headache haha
Yep, they're the eaton-style chargers and not the centrifugal ones (fake turbos I call them hahaha). I'm looking at the Magnuson MP2300 charger with 60lb injectors so I guess the $6k kit would be the ones with no injectors and using the smaller MP1900 charger :)
Turbo for that GATE
You boys are NOT making the decision any easier hahaha
Lumpy cam in a V8 with screamer? Should sound ok I guess haha :whistling:
VE GEN-TT Intercooled Twin Turbocharger Kit $ 7,995
if they sell for this in aus. they can be had for half price from overseas.
very easy to fit too.
Half? No way! Customs and freight will ream me to about the same price anyway won't it?
Also, I'm a f**king noob, I can't install that shit haha
Hahaha, yeah that's the only thing that is making me think supercharging, cos even though I LOVE the violent-ness of a car coming hard on boost with a turbo, the crappy commo would struggle to put that power to the ground I rec kon, even though it weighs almost 2 tons
If supercharging seems more straight forward and still retain the drivability, just go for that.
lt's still the same power out put yet can still use the power, for you setup.
someone say blown v8?
In my experience from actually owning turbo vs supercharged cars, I LOVE the 'rush' of power a turbo gives you (for me was my 33 GTR) but it has absolutely nothing down low, a v8 might fix that.. but you can't beat dem feels of full boost off idle too.
Making like 200+ rwkw at like 1500rpm means you can beat things without going over 3000rpm :D (ofcourse I'm only talking PD superchargers)
Around town / daily spec / less cop trouble supercharger ftw hands down love taking off from the lights no effort at all going through all the gears and being 100m infront of any other cars, fun / weekender I'd go turbo for the more 'lols'.
Around a track I reckon supercharger would be better with predictable power and straight curve, for skids can't beat supercharged v8 either :P
Both sound cool in their own way, I think turbo sounds will cause more cops to look at you though.
Edited by UNR33L
Do the SS's respond to strapping a charger on + tune as well as your GS did?
would make roughly the same power from what I've seen, biggest difference is my engine comes with the supercharger fitted on 'low' boost whereas an SS you're forking out another 10k basically. (not including supporting mods like exhaust etc)
the fact mine came with it from factory means cops can't touch me too, which is nice.
Edited by UNR33L
Guest
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
