So yours was pretty much just a new pulley to up the boost a bit and tuning the stock ecu... then a few supporting mods. You had to do injectors as well yeah?
my pulley is still standard, the computer controls a 'wastegate' type valve that bleeds off boost from factory. injectors standard as well, only supporting mods I did was tyres and coilovers lol
If I wanted more boost from where I am at the moment would need a new pulley, but along with more boost would become more heat, needing intercooler as well, and at that power level need injectors as well! This is why I'm happy with 'only' 370rwkw
Barring shitty forced induction setup, I would expect a bit more power given an extra litre of displacement...
not really, the ford heads meant to flow a lot better I think, thats why they make awesome power from just 5.0l (something along those lines) the design of the LS engines pretty old school in comparison - michael the bloke with supercharged XR8 would know more about the differences
Edited by UNR33L
The problem with Leigh's car is that it's too perfectly in it's power delivery...see above. It still feels quick but not as quick as you are going. Your joy needs to come from smashing other cars, getting the tale out or getting to ridiculous speeds quickly.
The G tech picked up greater instantaneous G force in my car, which was a lot slower.
Which is why I say blower for drivability, turbo for fun.
Guest
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
