Pics of black VE SS utes with decent rims.... considering getting aftermarket rims, or just powder coating the stock 19's black to change it up when I get new treads...
No bigger than 19's though, still need to tow the bike etc with it ..
tell me about it, every time I fly out thow out a fridge full of stuff.
such a waste
or end up eating out instead of buying stuff in also wasting money
I feel your pain brother.
All dat wastage.
Coles offered 2 for 1 pack of cherry tomatoes!! I didn't even get a chance to open the second pack before turfing it.
Damn you society for making everything family size/deals
so I google varreston commodore as there a set I saw on a VE a whiel I actually liked
and what do I get returned
haha
and yeah pretty sure the above same as mine I had 20s on some concave style but back to 19s with phat tyres <3
Edited by UNR33L
This is mad:
10454079_531686560288091_283796237126407
Heres the link anyway to fb group I have liked have a look:
https://www.facebook.com/SlammedHsvsFpvs
it's easy, just find good jap style rims in good offset - throw on holden / ford - then look better than 99.9% of other ones out there
Edited by UNR33L
artworks-000042030583-sysjkt-crop.jpg?30
Yeah, but you think D1R's or whatever they're called, look good..
This is mad:
Yours are 19" in that photo? they look smaller... Would probably look even smaller on my car with the bigger guards...
No point getting ideas off the ones you posted above when they've got massive flared/bolt on guards and slammed within 20mm of the ground.....Won't look anything like that on mine..
Yeh mine are 19s in that pic, the reason they look smaller is because I went up a level of side profile in the tyres for more grip as well.
Prob with 20s as well is makes brakes look tiny.
Guest
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
