I run 34 rear, 36 front for daily driving,,,
Driving home today my oil pressure went bye bye on the gauge, engine is still running, think its the pressure sender unit. Bah, so annoying to get to :/
Brashes
Oh and while we're being old...
Remember when the Matrix came out? How cool it was and the amazing CGI? Babies from then can drive a car now.
remember when marty mcfly went back to 1955, how old timey it was....
If that film was made now, he would have traveled back to ~1985
hamish
are you meant to run same pressure at all 4s?
according to manual
fronts 31psi
rears 27psi
first ive heard of it
I usually run same same in the evo as traction is not an issue
tyme for sarnie plate, oil cooler and aftermarket gauges.
Did it again in the middle of my drive to work this morning. Bah.
Already has the OEM oil cooler deleted, using N/A coolant hoses around the block under the intake runners. A Tomei Thermostat unit directly on the side of the block, a Tomei filter relocator and a big oil cooler in front of the Drivers side wheel.
Need to bung in my oil temp sensor to the tomei thermo, replace the stock pressure sender and then I'll be Happy as Larry
10506675_10152068103611148_3939969532096
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
