That's what's doing my head in. Suppose I'll have to take a passenger ride in someone's gtr to see if they're all they are cracked up to be
In this day and age it seems a well sorted gtt/gtst and a well sorted gtr are much of a muchness as far as actual speed is concerned, unless I'm wildly incorrect
  • Like 1
went to a steak house and ordered their top steak to be cooked as per chefs recommendation, just like wasteland said.... "I'm sorry but you'll have to pick something because I have to write down the order for the kitchen"
Speed perhaps, how they are to be driven is very much not the same though.
Ask to speak to the chef, and then tell the chef to hit the waiter over the head with a spatula...
Chef's recommendation coincidentally blue everytime for less cooking effort
inb4 Hamish hates me
  • Like 1
I'd assume the difference may be traction
shitcunt waiter :/
Actually...
Contrary to popular belief, bleu (it's French fgt) is annoying as hell for a chef and takes longer to cook than a med rare etc.
You have to get the steak out of the fridge and leave it somewhere that will warm it through all the way to room temp without cooking it at all... Which takes ages... THEN you have to cook it... THEN you still need to rest it.
Bleu takes as long to cook (properly) as a well done and ends up with complaints more often than a well done
Actually...
lol i can imagine.
It's just nice to be able to drive on the street with 330rwkw and not have any fear of a full EPA or Defect. GTR engine bays can remain completely stock looking and still make that power which is great. The others are correct though, depends what you like driving more, I've owned 2 33 GTS-Ts, a 32R and now a 33R and the 33R is just miles ahead of all of them.
Guest
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
