Lol sorry Birds, but it does look like a teenagers wallet. Takata or not, most people who see you pull it out will think its a ripcurl velcro job
Let the ignorant be ignorant :)
Those who appreciate will make it known, which is better than a myer spec JAG will do for anyone!
There's a plain black one for the non-JDM nerd folk
http://m.seatbeltbags.com/mens-seatbelt-wallet-black.html
fyp for age accuracy
fkn lol
you have a 17yr old kid and a 35yr old man inside you...: :blink:
sounds gay bro and somewhat paedophilic
I knew it while I was typing it...
I still typed it
Because everyone with a phone camera wants to make their pictures look like the pros do
Not unlike the dimwits who watch videos of juiced up 10 year bodybuilders working out and try to replicate their routines
I loaded the new ones up into MYOB today, This fortnightly pay period ends on Friday, so payroll will be done on Monday morning.
Does this mean MYOB will do 5 days at the new rates, 5 days at the old rates?
loling hard at occupation list in E-tax 2014
Leaflet deliverer
Keno terminal operator
Victoria Police Officer
Jillaroo
Import export clerk (Art Vandelay)
Ice cream van vendor
Host
Grave digger
Ganger
Egg grader
Drummer
Cyclist
Comedian
Chocolate packer (bahahaha)
Chimney sweep
Caravan salesperson
IT admin
Cake decorator
Bungy jump master (seriously?)
Monk (they have incomes?)
Personal assistant (glorified)
Pest and noxious weeds inspector
Noxious weeds and pest inspector (yes, twice)
Rabbi (paying job?)
Sandwich hand
Shot firer (where is shot caller?)
  • Like 2
lol I saw one of these at a charity auction a few weeks ago, wasn't a fan...it looked cheap, like a copy...but was legit from a jewellery store. Someone got it for $450 from memory.
I was referring to your gold blingers in the watch thread.
Guest
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
