How long would it take a machine shop to set up 4 wheels on their large scale industrial lathe, taking the correct amount off and not risking upsetting the balance of the wheel in any way.
I'd imaging it takes a decent amount of time to do considering you're grinding inside the area you would normally mount it with... So it's gotta be done using clamps around the outside of the wheel.
If each wheel was completely done in 15 minutes (wouldn't be), that's only $80 an hour for precision work on a machine worth many thousands of dollars.
now feel sorry for the guy and will pay him extra.
freedom=your welcome etc. etc. etc
cos Afghanistan and Iraq were totally invading Australia...
my freedom was set the minure I was born a white male in a 1st world country
lol.
the kosovans and the northern irish were not invading either chum. dont forget them!
neither where the Somalians or the kenyans for that matter!
or those Indonesians that had there houses destroyed by a tsunami, or the haitians whose country was destroyed by an earthquake.
no your right mate. should have just been a chef aye.
btw the freedom thing was a piss take, but since you had a bite.....
My freedom was when I was 18 and finally allowed to do what I want, legally abiding by law. And not breaking any rules and doing what is socially perceived as acceptable..
I feel so free
I feel so free
your welcome.
I feel so free
My freedom arrived the day I forgot to wear underpants
And I'm freeeee
I'm freeee ballin'
like i said ill give it a chop my self. i know an hour of my time aint worth 80 bucks. being a veteran an all, all im fit for is shinin shoes and saluting the flag.
ill get em balanced after, if it dont work ill get he other done properly.
thanks for your input victoria.
as flamin mongrely as usual.
That was literally just on the radio? Coincident? Conspiracy? Illuminati is watching
This is the core of the issue... You don't think it's worth $80/hour to do, however for a skilled machinist in a shop dedicated to tasks like this it is...
They've got to pay Wages, overheads, Rent, Cost of Equipment and Consumables, Superannuation, Taxes, Power, Gas, Advertising and a skinny philo called mikeymike to sweep the floors. They're a business, if that can make a small profit after that they're doing well.
This is why I DIY as many things as I can, only going to specialists if its something that I can't (or it isn't cost effective for me) learn to do myself using my own tools.
You're a tool
lol.
too easy platz...
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
