Do you miss your balls? What did they do with them after they got cut off? Did you get to keep them in a little jar?
Naw mang auto is faster and way better gearbox in general
If I want my balls back I go on my 'manual' motorcycle!
So all these new smart watches, good or gay?
http://www.news.com.au/technology/set-solutions-video-shows-vision-of-apple-iwatch/story-e6frfrnr-1226977391317
functionality looks alright, but can't see myself wearing one of those
I'd punch any tech hipster wearing that in the dick, fo sho.
Birds will backhand him while wearing his pretty watch, as long as it will inflict pain.
Any chance to touch another mans penis right?
Current Android ones are pretty gimmicky and useless, will be interesting to see what the iWatch does though (don't think I'll be picking one up either way).
If it's like other apple products expect it to have half the functionality of the android versions until the 5th or 6th release which will be behind in other areas instead :P
What Apple products are lagging behind?
without getting into the usual "apple vs everything cos they're the best even tho ive never used anything other than this shitty iphone" debate,
i just jumped ship from iphone 5/5s to galaxy s5 as one. you cant compete. s5 every time. battery life expandalbe memory, a camera that is actually good. etc etc. iphone is so far behind it isnt funny.
It depends what you're after. Most people consider the iPhone 5S camera to be superior to the Galaxy S5, not to mention other hardware features like a much better fingerprint sensor, better build quality and no bloatware on the OS.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
