Anyone know of a good automatic transmission specialist in Melbourne? Just looking to get the fluid completely drained and replaced.
And what about a decent mechanic for Skylines? When the car starts in cold there is a slight rubber grinding noise, which I believe to be either a belt that's not tensioned correctly, the starter motor or the power steering pump (when the car starts moving and after I turn the steering wheel there is a noise for about a second after I finishing turning, so it could be the power steering pump or belt) not too sure. I think it's similar to this: http://www.skylinesaustralia.com/forums/topic/362803-r34-gtt-power-steering-pump/
Where are you in Melbourne?
Rob at Sabbadin automotive in Mulgrave is good with skylines and is hosting our upcoming tech night too.
http://www.skylinesaustralia.com/forums/topic/445014-sau-vic-tech-night-discussing-e85-thanks-to-wolf-motorsport-sabbadin-automotive/
I'm in Hawthorn, but my parents house is not far from Sabbadin Automotive so I can make it near there. Could they also do an automatic transmission flush?
It's not that tricky to do is it? Just drain and fill?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
