It's not that tricky to do is it? Just drain and fill?
Unfortunately automatic transmissions are a bit more complicated to do. To drain all the fluid out you'll need a machine to pump it out, if you do it yourself you'll never 100% drain it properly.
I've tried it before on my FTO and by using a few different methods the maximum I could get was 4.5L / 7.5L, it's a piece of mind knowing that you can get it 100% changed over.
Sometimes I miss my old VL. Steering racks leaking, buckling wheels/panhard rods from drifting into gutters on rainy winter days. Filling the boot with bricks to give more lows. Freeze plugs rupturing coolant into my driveway.
I need to buy another 80's shit heap to keep me occupied. What I would do for an old Honda City turbo.
500 dorra buys my shit-house 31.
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
