Unfortunately automatic transmissions are a bit more complicated to do. To drain all the fluid out you'll need a machine to pump it out, if you do it yourself you'll never 100% drain it properly.
I've tried it before on my FTO and by using a few different methods the maximum I could get was 4.5L / 7.5L, it's a piece of mind knowing that you can get it 100% changed over.
DTM autos in geelong know how to do this (from experience)
Long way, but hey I lived in Hawthorn and went there..
I don't think there's a way to do it 'easily' though, it essentially needs to be running to flush the fluid out, and continually have new fluid put into it until everything inside it is new fluid. So if it holds 7.5L of fluid, you'll be using 10+ for a full flush as you can obviously never run the auto with zero fluid in it ;)
Thanks for that. Geelong is a bit too far for a simple automatic transmission flush haha. Yeah I figured I'd need 3 bottles (12L) for the full flush, will have to see what else is local :)
greg always does things the hard way.
the jatco auto box is actually in patrols and shit as well, any auto shop should be able to service it, its nothing special.
Lol when you get them you'll think they look really weak. Then you will question them.
Then you will question life and everything in existance and you will start growing your beard and hair because you will assume the hair dresser and clippers are out to kill you
Soon you will stop paying your mortgage and rent..
And you will be on the street warning everyone that judgement day is coming and then you will look back at what birds told you and think "I should've just driven the f**king thing"
yep. Anyone can service it. All you 'need' to do is add it at the rate you're losing it, easier said than done lol.
Also, anyone want to buy a forged RB28Neo?
Now with actual seriousness.
Guest
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
