Oh okay. Probably still the extra legroom row that they'd charge $60 for, just without exits.
One bag was 25kg, the other was 19kg and the limit is 23kg. She'd already booked extra luggage online for the second case. Then at check in got charged $70 for extra luggage cause one case was over limit (and they charged it to cover both ways, when she would have only needed one way even if she didn't purchase extra baggage online). She was in a rush so didn't question it, or have time to swap from one bag to to the other.
Ah that's crap. Sounds like something tiger/jetstar would pull.
Let me know how it resolves.
actually funny that.
Landed this morning from amsterdam with free business class upgrade ;)
Cathay Pacific looked after me nicely
never have that much luggage tho, as only travel for 2 weeks at a time I'm generally under 25 kg total.
you probably don't take a 33 headlight in a suitcase either.
So whats the go? After all this you're going to part out and walk away?
it looks like he is taking the easy way out and going gtr.
why he would get into a slower car i dont know.
That car is cursed
It got statutarily (whatever) written off.
I did the math on whats actually in it, and how much the parts would cost if say, you were to buy them new. (99% of the parts on my car are new or very unused). That number was about $35,000 in just parts. (obviously selling them at 1/2 of new price to actually you know, sell them)
The wreck kind of didn't cost that much.
I kind of want something that will be EPA proof, I like 4WD for grip under power, and everyone always goes on about how manual is what you need to succeed in life, even though anyone who tried the auto thought it was suprisingly good.
I see limited logical options.
Other option is buy this: http://www.carsales.com.au/private/details/Nissan-Skyline-1999/SSE-AD-2098166/?Cr=7&sdmvc=1
And put everything in there. But "putting everything in there" is a huge amount of time, effort, or money, and it's still smoke and mirrors hiding from the EPA, as opposed to having the same power (and basically same lag) and not needing to hide turbos.
5k in suspension in my r34 to obtain grip in the rear (which worked very well admittedly) or traction control via front driveshaft.
How much would it really cost to transplant 100% of a car into another one anyway? 5k? So 13K total (in this example) which still leaves me ahead.
But less ahead than buying someone's forged GTR as per here: (http://www.skylinesaustralia.com/forums/topic/444348-r33-97-gt-r-v-spec-series-3-29000/?hl=%2Br33+%2Bforged#entry7310159) or (http://www.skylinesaustralia.com/forums/topic/439783-r33-gtr-vspec-forged-engine/?p=7211282)
...and selling the wreck.
ofc if noone wants the engine, I'll have to put it in something. Shit is definitely doing my head in right now ;)
Go to Vicroads
Sight new engine number.
That's all there is to registering it, as I've done that part before...
You'd replace every part though. Engine, Transmission, re-wire both ECUs, diff, half shafts, rear suspension, fuel pump, fuel pump wiring/relays, Radiator, Gauges.
I mean its doable, sure. Its just a lot of hours. Hours that a workshop charge a lot of money for, if you want it done right. I asked scotty about it and even he said "its doable but I'd have to hire someone, have you got quotes from other workshops?" which is all for....
a massively EPA'able (though well hidden) auto sedan, vs a car built up from the ground to be a 4WD performance car. That said, I'd have all the stock bits to pass an EPA, as I'd have a lot of spares with, you know, an entire spare car...
I have a 95% hate, 5% love relationship with this thing. I think I need to go for a spin in a well sorted GTR to see what the differences really are, as I can only compare it to a Stagea, a S15 with about 260rwkw, and a 1979 BMW, and an Evo X, none of which are similar.
The Evo X (210kw) did make me think I've been doing the wrong thing the entire time. Said Evo X driver said he disliked the Evo and really wanted his R33 GTR back, leading me down this path of "sensible" decisions.
Should I mention the previous two owners died shortly after selling it?
Should I mention my daily shitty Camry's previous owner also died shortly after selling it too?
Unsure if I have killed it, or the curse is getting extremely crafty, after I refuse to sell and pass it on.
I've said many times over the years "if I could do it all again, I would have got a GTR for 11 million reasons" and now the hand of god literally reaches from the earth to push the reset button.....
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
