Finally got my car back today :) Although I don't think the wheel alignment was done properly, steering feels a lot heavier and for some reason the car feels slower :\
maybe you got excited for boost but was let down by stock.
time for some hypergear + scotty hi-flow.
Always took simon for a receiver, not a giver.
This I can confirm!
Have a look down near your Alternator, in front of it (sort of below more so), theres a power steering line which should have a sensor tee'd into it. See if someones undone that plug as it's fairly common cause of the steering being heavy.
This I can confirm!
Thanks, I'll have a look tomorrow. I had a quick look at my car tonight (through the heavy rain) and I think they've done the alignment completely wrong though, seems the camber (and possibly toe) are out, which explains why it feels slower as well.
Did you get your Alignment printout? Get it fixed if they've screwed it up badly (it's gotta be hellishly out if its actually causing so much drag you can feel it being slower)... and it'd be munching through tyre already
Dan Murphys have a limited edition royal salute for $120 a bottle delivery only
bought one for myself and 2 for the old man and orders over $300 are free delivery
https://www.danmurphys.com.au/product/DM_779879/royal-salute-world-polo-21-year-old-scotch-whisky-700ml
Nope, the panel beaters took it to another shop to get the alignment done so I don't have any documentation. I knew I should have sent them an e-mail with the wheel alignment specs, most shops are horrible at getting the right specifications for imports. I remember on my last car when I needed a wheel alignment and I told them I have the specs for it, they just said "Don't worry, we'll work it out" and I foolishly believed them. Got the car back and it was terribly out of alignment, they are just too lazy to look it up.
I'll be calling up tomorrow to get them to fix it, because it definitely doesn't handle as well before the alignment.
DMWEL0714 should give you free delivery too, alternatively
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
