this.
flamin mongrel with "fastest micra in aus" has 148kw with 10 grand forged engine.
i have 170 with 200 dollar 300000km shit box.
ethanol man.
170 at 9psi mang, don't forget that.
When are we winding the boosts up ffs?
  • Like 1
I agree with this sometimes in the case of boredom, but now that my car is where I want it modification wise, I have no desire to modify further but still want to keep it.
Best if you can modify a car 'properly' not long after you buy it, that way if you keep it a few years you will get some good use out of the mods, and not blow your cash.
Unfortunately some workshops/owners don't know what the good mods are.
3076R Low doesn't look TOOOOO different to a stock turbo ;) Considering I'm without a heatshield at the moment anyway. Dat noise tho, pppsssssssss
Edit: Hmmmm, what do they make on E85? 330rwkw?
Buy my entire setup.
GTX 3076 will make 450kw or so on the right setup. Greg made 380 with his auto... return flow, stock airboc, 3 inch dump and intake. Stock officer. Personally I would go with the gtx71 for some extra response.
Garrett list them at 230-390kw
Go hypergear bro. Cheaper, local support and some really nice turbos on their menu lately.
i call bullshit on 450... no offense scotty.... but seriously what is that like 100psi?
Apparently 45psi, someone has done it on a SR20.
That said, was in a magazine. I was sceptical, but given I got 405 on 28ish psi, I see no reason that 15 extra psi wouldn't result in 50kw...
Inb4 stao
Inb4 toby's 400kw
HG turbo checking in, 15,000km and spinning like the day it was put in
I'm not saying they don't work but really they are not very much if at all cheaper than Garretts and due to having a plain bearing core you do lose some response(and that cool whirr down noise after the cars turned off :P) I just don't see them as excellent value for money.
hiflows are. other than that? no.
Guest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
