dirt bikes are for bogans who like ruining forests and destroying silence for kms around.
i'd rather support hunters/shooters who actually enjoy the outdoors.
save your coin. for someone who lives at home, you sure do have a lot of space to put your toys.
That's rough man :( :(
I see your lengthy weapon and raise you pyjamas no self disrespecting hipster could ever cut through
2012-autumn-and-winter-new-men-and-women
I will cut around it so you bleed out slowly and painfully. you now have the added insult to your family of your corpse looking like a douchebag
I'm not saying they don't work but really they are not very much if at all cheaper than Garretts and due to having a plain bearing core you do lose some response(and that cool whirr down noise after the cars turned off :P) I just don't see them as excellent value for money.
Recon your $2500 500HP Garrett can beat one of mine $2500 500HP SS-Alpha in response? :rolleyes:
And Ball what bearing?
I choice to not to for good reasons.
you should always take into consideration the HELP/HECS repayment based upon your HRI dude
At least then you will know exactly what your tax position is
I can always dream can't i?!
Bro tip to self: buy more negatively geared properties
I'd blind you with a camera flash and given Apple doesn't support flash you'd be fresh out of luck
It's more of a joke to defend Flash these days :P Android doesn't support Flash either, it's a dead application.
Turbo looks good, but unfortunately its Chequered, so it's more like 350rwkw not 435 lolololol pls.
  • Like 1
You do realise that Trent uses a correction mode that gives basically the same results as a dyno dynamics... Only more accurate...
Just cos he does a better job than your mob for half the cash is no reason to hate :P
Guest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
