Where to go to get some QM1 mixed up into a spray can?
I've got a front bar at home that I want to paint.
Any idea of a rough price on a can of basecoat and a can of auto acrylic clear?
You do realise that Trent uses a correction mode that gives basically the same results as a dyno dynamics... Only more accurate...
Just cos he does a better job than your mob for half the cash is no reason to hate :P
We've dyno'd cars that the previous tune was with Trent, and they are a HUGE difference in readings. Donello Performance has dyno'd cars after Trent has tuned them and still, 50-100kw difference I shit you not. I know of a 33 GTR that's currently about to have an engine rebuild, supposedly made 500kw on Trents dyno even though the turbo's he had on it are not known for producing that power, and guess what, dyno'd and made no where near that, couldn't even crack 400rwkw.
Add to the fact that today I just removed an engine from a GTR that had been tuned by us, then he decided he wanted more power, went to Trents, got more power, then it pinged and put a hole through the piston the next time he went to the track. I wish I could say that he's a good tuner, but even driving the cars in and out with his tune, lmao trying to start them in the morning... don't even get me started on his E85 Cold Start tunes.
The only people rant on about Trent is because he gets big power figures, so forum warriors can fap over it and brag and omg its so fast hes actually the best... yet they've never really had it tuned elsewhere to know what they're talking about.
Also just FYI, the average tune costs $5-600 iirc, I don't think Trent is doing them any cheaper than that, but I guess the saying rings true, you get what you pay for.
  • Like 2
I know of a few horror stories from race pace too FYI... But I had enough respect for the business to keep it to harmless jokes and not outright slander.
Speaking of jokes, maybe I should post the racepace quote for an RB25 straight swap I got a coupe of years back ;)
We've dyno'd cars that the previous tune was with Trent, and they are a HUGE difference in readings. Donello Performance has dyno'd cars after Trent has tuned them and still, 50-100kw difference I shit you not. I know of a 33 GTR that's currently about to have an engine rebuild, supposedly made 500kw on Trents dyno even though the turbo's he had on it are not known for producing that power, and guess what, dyno'd and made no where near that, couldn't even crack 400rwkw..
Trent has been tuning my cars since 2007, and I have had no dramas, all four cars he's been tuning is running fine so far.
About the dyno differences. I'll post up comparison against a more know turbocharger for example the SS-4 Alpha model you've seen earlier.
Standard GT3540 equivalent in .82 rear:
R33 GTST, Factory spec engine, with high mount and external gate.
431rwkws @ 25psi E85 fuel, full boost reached at 4650RPMs
ATR43SS-4 Alpha. That makes 435rwkws @ 25psi also, while making full boost by 4150RPMs, Nothing's changed except turbocharger:
Using this turbocharger, you are expecting similar amount of power as a GT3540 with better response. So that might be making more sense to people operating other branded dyno meters.
Also which workshop are you operating from?
Oh I understand that, I think every workshop probably has a gremlin or two thanks to the internet. I just don't like the fanboyism of Trent on the internet, sure he can tune and quite often there can be no complaints, he does a good job. I've just seen too many first hand to go "Nope no thanks!". Also all workshops quote exorbitant prices when they don't want to do the job just FYI.
Edit: Very impressive figures Stao!
:turned:
Broci88:
In terms of tuning, lot of us do our own road touch ups and etc. can you explain some of the areas that you might be able to get the car run safer and better?
How is this even a legit question to what I've said? I said I had experience with poor cold start tune, and know of a customer of Trent's who blew a hole in his piston because of excessive pinging, how does that correlate to me saying I could tune it better?
Sorry that it seems a little far fetched that you're making more power through a factory 2.5L than what a 4L Barra can make in the XR6 Turbos. When it's posted in a shootout mode through a tuner other than Trent, then I personally will believe it, but I don't think you should worry about what I think as I'm not the type to go out on fb and "omgzzzz best tuner ever omgzzz must tell everyone" like every other factory S14 owner seems to believe.
  • Like 1
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
