good-good-let-the-jimmies-rustle-through
All I'm saying is a dyno day my car made more than a e85 shoop da wooped external big ass turboed 500kw 11ty supra brah
I remember that... The Chasers one where you were repeatedly predicting 400kw before it then pulled ~350 ;)
Eh, only had another dyno to compare to from when I got it tuned
Still came runner up, only to another ford ;O
http://www.estblshd.com.au/dyno-day-presentation-night/
351kw of NA powaahhh
Edited by UNR33L
yeah...
falcadore Ute
2 x V8's (neither running)
bathurst camp sites booked.
had dirt bike
and the latest thing that apparently all bogans need.
a frequent flyer status...
haha gold
I forgot I drink VB too
Platinum level
indeed...but qantas..none of this import virgin shit...
haha gold
actually I drink VB as well.
brought up with it and if I turned up with anything else my mates would beat the crap out of me..
How is this even a legit question to what I've said? I said I had experience with poor cold start tune, and know of a customer of Trent's who blew a hole in his piston because of excessive pinging, how does that correlate to me saying I could tune it better?
Sorry that it seems a little far fetched that you're making more power through a factory 2.5L than what a 4L Barra can make in the XR6 Turbos. When it's posted in a shootout mode through a tuner other than Trent, then I personally will believe it, but I don't think you should worry about what I think as I'm not the type to go out on fb and "omgzzzz best tuner ever omgzzz must tell everyone" like every other factory S14 owner seems to believe.
It might be a wrong thread asking technically questions, I'm learning and doing noob road tuning. I will post specific inquires in my own thread.
Different Dyno meter may interpret HP differently with terminology used. I'm not expecting two branded dyno meters to read similar numbers. Like I've said, I'm posting up comparison result to commonly used turbochargers for more accurate prediction. I there for has no bias or doubt in your own tuning abilities just because your dyno might read differently.
There is no need to be upset
Probably worth noting that the same turbo/motor setup, on the same boost as my car, tuned by racepace made the same power as my car on Trent's dyno. My car also made the same on about 3 others give or take ~5%
Oh, and the same as every other person on SAU running a RB25/2835
And workshops that don't want work don't type up comprehensive quotes, email them to the customer and then make follow up calls to explain how although they know their quote is more expensive they are worth it because "you get what you pay for"
Guest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
