^ this
also Ric you were right.. that dirt bike definitely wasn't a 'winner' after taking it for a 2 minute ride was leaking oil out the gearbox like a motherf**ker
Sell everything in your room and purchase new bike or one from a stealership?
^ this
I didn't say anything about the bike lol but you're welcome
twas me. wheres my credit dammit.
maybe i should charge $150 for an opinion on used cars...
D:\Games\DOS DOOM>dir
Volume in drive D is storage
Volume Serial Number is D326-902E
Directory of D:\Games\DOS DOOM
01-10-1994 08:02 PM 3,079 SIMPSONS.TXT
21-02-2012 05:24 PM <DIR> DOOM2
30-09-1994 10:47 PM 2,771,135 SIMP_GFX.WAD
29-09-1994 10:45 PM 1,250,002 SIMP_SND.WAD
24-01-1995 09:22 PM 56 SIMPSONS.BAT
15-11-2012 12:50 PM <DIR> DOOM
4 File(s) 4,024,272 bytes
2 Dir(s) 3,459,167,842,304 bytes free
Wastelanders, any of you guys know where to get service reminder stickers? Those little stickers where you place in the windscreen to remind you when to service.
Could only find American ones on ebay...
Or am I the only one having the trouble remembering?
I've got rolls and rolls of em. Grabbed em from a workshop that closed down who were selling everything off. You can have a roll if ya want. Going to any sau events soon?
Don't they come with each bottle of oil these days?
None of my bottles... Using Nulon
Was meant to go to the go karts one but prob not now.
You're not anywhere near the western /northern suburbs are ya?
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
